NurseDoe
There was a huge lawn and lots of trees out back when I moved here 25 years ago. Everything was on wonderful automatic timers-the lawn, the trees etc. Drought happened so I let the lawn die many years ago. Now, I want to use that same system if possible to set up irrigation-likely drip for all the plants and trees.
*There are about 5 valves in a box close to the house.
*Wires still run to them all and the timer box still turn on.
* I have no idea where all the old things are-I know the pipes were broken, sprinkle heads put up and water has not been on in years
* I am willing to do this all myself or with some volunteer family.
* I am sitting with the Ortho's book on sprinklers and irrigation, which assumes I am putting this in for the first time. So is not as helpful as I had hoped.
Questions
1. Where do I start? ( I am thinking with gloves to clear all the dirt off the valves- some are missing that X type shut off and on handles).
2. Should I just replace/update the timer and wires?
3. I want to run enough solid PVC pipe to each section ( one at a time) so I can hook up a drip irrigation system again. I am assuming I can just disconnect the old pipe at the valves and put new pipe? One section about 20 feet and another about 50 or so...
I actually have asked a couple of plumbers to help and it is not something they are interested in doing. You guys have helped me through so many projects in the 1950's ranch home that is falling apart- I am hoping you can give me some ideas to keep the costs down.
#tinyhousesoundsgoodtome
Questions
