Review Shower DWV Diagram Please - ready to install
rafigso
Greensboro, NC
Good Evening,
Thanks in advance!!
I'd like to know if what I represented would work, here are some notes:
1. ABS is 2"
2. I'm going to remove the old P-trap from the vent and cap it in order to reutilize the vent for the new shower
3. Can I utilize a 90 degree turn in the waste run from the p trap before the vent, did I say that correctly?
4. Where the waste pipe meets the vent, do I need to use a T or a Y or does it matter?
5. In order to get the slope I need, it seems to me that the pipe gets cemented in at a slight angle, is that correct?
6. When installing the P-trap, does it rest on the drywall from the downstairs ceiling or is it slightly raised, not sure at what depth to seat the P-trap in relation to the joist and subfloor.
7. What's best practice when installing the drain, do I cement a piece of pipe prior to subfloor install and cut after subfloor goes down or do I cement in drain pipe after subfloor.
Here is a picture:
Thanks,
Rafael
1. ABS is 2"
3. Can I utilize a 90 degree turn in the waste run.
You can have 135 degrees of change after the vent.
Most codes like a wye fitting in case someone tries to wet vent later on.
Fittings are made with that angle built in. 2%
Once you have set the p-trap height, it drains down at a 2% slope toward the vent. No..........You can't monkey around with fittings and change that!
That depends on what you are using for a shower pan.
rafigso
Greensboro, NC
I have some follow up questions and have color coded them Green, thanks for the quick reply.
1. ABS is 2"
So is the 90 in the diagram before the vent allowed?
Do I set the P-trap off the celing or rest it on the ceiling?
I'm thinking of using pro-slope and then mud
