Reversed tub overflow assembly?
Discussion in 'Shower & Bathtub Forum & Blog' started by Mattoest, Aug 21, 2005.
  1. Mattoest
    Mattoest New Member
    Aug 21, 2005
    I am helping a friend replace a tub drain. We are doing other work in the bathroom and opted to just remove the tub to make it easier to get the old drain off. When we got it out I saw that the overflow assembly is 'reversed' from the normal installation. The overflow arm drops to a 90 degree angle and meets the drain with a T, with the tailpiece droping straight from the drain into the trap assembly. Can I buy this type of assemply anywhere or will I need to make one from a normal assembly and other PVC parts? It does not look like I can reposition the trap to accomodate the normal overflow configuration without removing 80% of a floor joist at that point. Do you anticipate other problems with connecting the modified overflow? I imagine I will need to cut an access panel in the wet wall (it backs to a closet) to reach the nuts. Thanks.
  2. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    Put 'er back the same way!
    Sounds like the drain was assembled this way to get out of the joist situation, which lets face it... sometimes you just have to do. This is a modification of the drain parts to make it work, and although not ideal, I'm sure it's been working alright. I would redo the drain configuration the best way you could, we just want to make sure that we are definitely draining and venting unhindered. I hope I don't get a verbal lashing from the others for condoning this! I have been in the same situation and have had to take the same measure, as there was absolutely no possibility of relocating that joist!
    You will need an access panel to make the pipe connections once the tub is in its place.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    W & O
    If I read the situation properly, You could order a W & O assembly out that would cover that situation......
Similar Threads: Reversed overflow
Shower & Bathtub Forum & Blog Shower cold and hot reversed??!! Feb 21, 2015
Shower & Bathtub Forum & Blog Hot and cold water reversed. How do I fix it? Mar 11, 2014
Shower & Bathtub Forum & Blog Hot/Cold Reversed on Moen Single Handle Shower Knob Apr 15, 2012
Shower & Bathtub Forum & Blog Walk-in bathtub reversed drain Nov 27, 2011
Shower & Bathtub Forum & Blog Shower valve - open/closed reversed Jan 26, 2009
