reverse osmosis makes noise
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by vegashomes, Sep 10, 2008.
  1. vegashomes
    vegashomes New Member
    Sep 10, 2008
    I hear the noise of water running coming out of the drain for the kitchen sink. It is quite loud and sometimes goes on for hours. Is there a way to lessen the noise. Is this normal?
    Thanks
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Install the drain for the ro closer to the water level of the trap.
    less distance to fall the quieter it will be.
  4. vegashomes
    Sep 10, 2008
    How long is it supposed to run? Sometimes it runs for hours even though we just used a little water.
  5. jimbo
    jimbo Plumber
    A small home RO unit may only be rated at 3 to 5 gallons per day. SO if you use a few gallons of water, the unit will be doing makeup essentially 24/7
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Ear plugs:D
  7. hj
    Ro
    How old is the RO unit. Older ones did not have an automatic shutoff when the tank was full and kept trying to make water continually.
  8. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    As a general rule it takes 4 gallons to make 1 gallon of RO water. I located my RO unit in the basement, directly below the kitchen, and routed the line up to the kitchen sink for a POU faucet so I don't have to listen to tingling all the time:D
Similar Threads: reverse osmosis
Plumbing Forum, Professional & DIY Advice Reverse osmosis and cooper water line Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Drain Line Installation Jan 8, 2017
Plumbing Forum, Professional & DIY Advice Reverse Osmosis + Instant Hot Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Drain constantly running Jul 23, 2016
Plumbing Forum, Professional & DIY Advice Reverse Osmosis Install Jun 26, 2016
