Reuse a soldered fitting?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by newmex999, Mar 25, 2010.
  1. newmex999
    newmex999 New Member
    Dec 22, 2009
    Is it ok to unsolder and resolder a fitting? The fitting in question is the brass female threaded winged fitting on top for the shower head.
  2. jadnashua
    Yes. You still need to clean and flux it for reuse, and you may need to bang it on a hard surface while hot to remove excess solder so the new pipe can fit inside, but yes, unless it is split or otherwise defective, it is reusable.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It does take a little time and effort to get the old solder cleaned off so the fitting will fit over the pipe, so you might want to consider if saving a few cents is worth it. Even a seemly small amount of solder will prevent the pieces from slipping together. Other than that, there is nothing wrong with reusing fittings.
  5. aikid19
    aikid19 New Member
    Apr 10, 2010
    SW Pennsylvania
    Do you feel that there are no compatibility concerns between older and newer solder?
  6. Terry
    Aug 17, 2004
    The new lead free mixes well with 50/50 and a new coating of flux
    The lead free makes a much better joint.
    I'm able to "break" an old 50/50 joint by twisting the fitting.
    That would never happen with a Leadfree joint.
  7. Ian Gills
    Jul 24, 2007
    Ah, but you can't beat the flow of 50/50 with quicker wetting out as the solder heats up, and quicker setup as the solder cools.
    If you plumb for art* rather than drinking from, then it's the solder of choice.
    * Plumbing for art involves soldering together dry plumbing systems for the fun of it but never actually collecting them to a potable water supply for use. Not many people do it but a few of us solder joints for the thrill, normally at the weekends. Enjoying plumbing is what distinguishes DIY'ers from paid professionals.
  8. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    That fitting is $5.73 in my area at the big box stores.
    It used to be $2.73 for years, till scrap prices went up.
    $1.73 when I started plumbing.
    1/2" shower lug ell is the technical term I believe.
Similar Threads: Reuse soldered
Plumbing Forum, Professional & DIY Advice Cast iron shower drain--reuse or replace? May 20, 2016
Plumbing Forum, Professional & DIY Advice OK to reuse these PEX fittings? Nov 24, 2015
Plumbing Forum, Professional & DIY Advice Reuse dishwasher copper supply line? Jun 29, 2015
Plumbing Forum, Professional & DIY Advice Can I reuse the same Copper flare line connected to a gas valve Dec 18, 2014
Plumbing Forum, Professional & DIY Advice New Kohler Cast Iron Tub and Gerber Bath Tub Drain Reuseable? Apr 22, 2014
