Chassis
Engineer
Good afternoon all,
I am replacing an old metal drum trap, presently installed in a kitchen sink/disposer situation. The outlet from the disposer is about 3" above the horizontal trap arm. My problem is I don't think a standard PVC 1-1/2" p-trap assembly will work. It seems to me the trap will need to be lower (driven the disposer waste arm) than the existing copper DWV wants it to be.
So the question is - can I use a return bend (hub x hub) only as a trap? On the inlet side, I would install my own vertical tailpiece with a trap adapter, to attach to the disposer waste arm. On the outlet side, I would install a vertical run, with a 90 deg. elbow, followed by a run of horizontal pipe to the copper DWV.
Is this an OK installation? I am eliminating the normally-provided (in Home Depot) trap arm component of a p-trap assembly. Thanks for any replies.
