Retrofit and Air Gap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wlam08, Aug 8, 2007.
  1. wlam08
    wlam08 New Member
    Dec 18, 2006
    I have a dishwasher hooked up to my disposal with a high loop under the sink. Every now and then, I get a sewer-type smell in the dishwasher. I was thinking of installing an air gap, but I have granite counter tops that I'd have to drill a hole through.
    Can the air gap somehow be installed inside the sink cabinet as an alternative?
    [​IMG]
  2. jadnashua
    Don't know for sure, but if there is enough room on the rim of the sink, you might be able to install it there. If it is an undermount and there is no part of the sink, no. Drilling a hole in the granite isn't that bad.
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    If you've never drilled granite...get a pro to do it.
    By definition an air gap means it should be above the flood rim of the fixture (max height the sink basin can fill), an air break is what it's called when below the rim.
    Your local plumbing code will specify if you need one or the other.
    Best bet is to look at local code, local codes often refer you to MFG specs for APPROVED MFG's, in other words...the local hardware store may carry air gap devices that aren't approved by local code...so reading the specs would be moot.
    The reason I'm stating this is that air gap requirements on dishwashers vary, depending on local code. (geesh...I think that made sense)
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    sewer smell above the counter instead of in the dishwasher. Is that what you want? It could happen. A sewer odor coming out of the air gap so you can detect it more easily.
    i think the bigger question that needs asking is this. Why is a sewer odor present? Then, will adding an air gap solve the problem or make it worse?
    shortcircuiting the diagnosis, to say you want an air gap. What you really want is not to have any sewer smell ever.
    So.... what might be breaking the seal of the kitchen sink P trap?
    David
  6. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    Off the wall thought.
    Why not put a second p trap under the sink and only run the dish washer into it.
    If there is slack in the dishwasher hose why not put a dip in the line to keep water in the line.
  7. jadnashua
    Getting a diamond coring bit caught in a thick piece of anything can be a real eye-opener, so yes, you do need to be careful, and yes, getting someone to do it for you where they will warranty the situation is desirable. But, getting someone to do it after the slab's installation may be next to impossible since they won't want the liability. That leaves you to do it. The deeper the hole, the more chance for it binding. A jig to hold the drill plumb is a bonus here and a slow speed.
  8. Kilgore!!!!
    Kilgore!!!! New Member
    Aug 31, 2007
    The big problem here is siphoning backwards.
  9. got_nailed
    Jan 11, 2006
    check valve?
Similar Threads: Retrofit
Plumbing Forum, Professional & DIY Advice Shower Retrofit Project: Drain and Venting Questions Nov 23, 2015
Plumbing Forum, Professional & DIY Advice Existing 1 1/4" chrome plumbing trap retrofit. what would you do? Nov 1, 2015
Plumbing Forum, Professional & DIY Advice Retrofit to create HW Recirc system? Apr 20, 2015
Plumbing Forum, Professional & DIY Advice Retrofitting a ceramic disc faucet with the old washer/seat system May 13, 2013
Plumbing Forum, Professional & DIY Advice Retrofit meter with remote read Mar 9, 2013
