Schedule 40 3/4 inch has an internal diameter of about 0.804 inch.
The 2 inch pipe is vertical?
You have ____ clearance above the 2 inch pipe so that you could stick a rod of that length down the pipe.
The 2 inch pipe has an elbow, below where the 3/4 pipe sits so there is not a danger that the 3/4 inch pipe can continue in?
You can clearly see the 3/4 inch pipe when you look in? Note that you may be able to light up the outside off the 2 inch pipe so that you don't have to have to hold a flashlight to see?
I don't think a vacuum cleaner will have enough suck to pull the pipe out.
One possibility is to use a piece of wood, such as a long quarter-round or shoe molding, and gently taper it near the end. Feed the end into the 3/4 pipe and apply a little force to wedge the wood into the 3/4 inch, wiggle and lift out.
If worst comes to worst, cut the 2 inch pipe, retrieve your 3/4, and glue the 2 inch pipe back together with a coupler. Maybe you could think of a reason that a cleanout etc could be useful there and install that instead of a coupler.
