Results and video of my first DIY Solar Hot Water Project using 300' coil of Pex
Discussion in 'Solar and Geothermal Water Heating Forum' started by TheycallMeDave, Jul 31, 2011.
  1. TheycallMeDave
    TheycallMeDave New Member
    Jul 9, 2011
    Retired HVAC Owner/Tech
    Northern Florida
    YOUTUBE VIDEO : http://www.youtube.com/watch?v=YBqsrpBSua0
    [video=youtube;YBqsrpBSua0]http://www.youtube.com/watch?v=YBqsrpBSua0[/video]
    The project consisted of building a Solar Box/Oven for 300' of 3/4" Pex-B Tubing to sit inside of and was built using 2x12's with a finished size of 36"x36" . 1/2" plywood was used for the backing with 1" Polyiso Board sitting on top of that with a thick piece of sheetmetal plate on top of that --- everything inside the Box was painted a flat black including the aborber plate, inner / outer box walls , and Krylon Fusion Paint for the Pex Coil . The top of the Box recieved a double pane argon-filled Low E window in vinyl sash which has good light transmittance with ability to retain heat in the Box. Collector Box is on a 30 degree angle from vertical. Piped in parallel to the water heater so the house hot water supply is either fed by 100% Collector water or from the standby electric Water Heater (accomplished via bypass valves) .
    Results after 5 hours of recharging :
    90 f. totally sunny day :
    Temp. inside Box : 161 f.
    Exiting water Temp : 158 f.
    84 f. totally cloudy day with mostly rain :
    Temp. inside Box : 105 f.
    Exiting water Temp : 100 f.
    (The Pex Coil holds about 6 gallons, but since i live alone ... it is more than enough hot water for my limited water useage for 100 f. showers and occasional Dishwasher ; in fact on a sunny day I have to cool it down alot with cold water at the Shower Head so Im using less than the 6 gallons of Collector Water. I have the Collector Water bypassing the Water Heater (piped in parallel) and going directly into the hot water line to the house . The Pex I used has a rating of 200 f. at 100 psi and the CPVC leading from the Collector Box to the house is rated at 180 f. at 100 psi. Total material cost : $400)
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    A couple of critiques of this heater as-built (and I hope this isn't taken too harshly, as the intent isn't to trash the design, but rather to suggest improvements.):
    More heat would be collected if you'd left the interior metal shiny, and painted only the PEX. Painting the metal backing and sides raises the temp of the frame, not the water, which only adds to collector losses. Keeping the interior reflective allows the PEX to absorb much of the heat currently being absorbed by the frame.
    Without insulation on the wooden sides, the heat that goes into the painted wood is largely wasted since the R value of the wood is only ~R1.5. As built you have about 11-12 square feet of R1.5 (U0.67) sides, and 9 square feet of R6.5 (U0.16) back and ~9 square feet of U0.30 front glazing. The vast majority of the heat loss is out the sides- as it's the most square footage, and the highest U-value. You'd have been better off using only one layer of iso on the back and using the rest on the sides in terms of retaining the solar heat that made it into the box through the glazing, since even with only half-inch iso on the back, the back would still be less lossy than the entire un-insulated side frame. (Using 1" iso for both the back AND sides is still better.)
    Double-glass and low-E coatings reduce the amount of solar energy getting into the box, which is why all commercial solar flat panels are single-glazed and not low-E. It would perform better with a cheap single-pane un-coated storm window. Commercial panels use low-iron glazing for a slight performance edge over cheaper single pane tempered soda-lime glass but that's a fine point. The glazing used here cuts performance by at least a third. Going with 9 square feet of ~U1.0 single glazing is lossier sure, but it's the same order of magnitude the loss of the current 12' of U0.67 wood sides. But since double glazed low-E argon filled cuts the into solar gain, the lossier glazing still performs better overall (once you fix the lossy sides, that is.)
    By rejecting about a third of the solar energy with the glass, and absorbing half of what got into the collector with the uninsulated sides of the frame (and the metal plate in the back) maybe a third of the available energy gets into the PEX before it heats up and starts losing even more heat, but most of the heat gained is leaking out the sides. I'd be surprised if the net collector efficiency made it to 20%, but it's probably at least 10%. Better home-built & commercial flat panels would hit ~35% collection efficiencies at the outdoor ambient/water temp delta-Ts you were measuring, and much higher at lower collector temps.
    But it's the collection of designed in performance reductions that are keeping the PEX below the rated 200F temp with only 6 gallons of water as the buffering thermal mass. With more water-mass/lower-temp operation, more insulation, and painting only the absorber you could probably double the performance of this collector. As-is it won't likely recover the cost of materials in any reasonable time frame.
    [​IMG]
    Without insulating the pipes between the collector and the tank you're losing quite a bit of the solar heat gains as heat dissipated under the house too. (More true of shorter draws than of shower-length draws.)
  4. m151
    m151 New Member
    Aug 16, 2011
    northern california
    I liked your design, simple and straight forward.
    Your choice of 3/4 inch pex should keep the flow rate up .
