Resin-Tech CG8-BL vs. CGS-BL
ditttohead
Water systems designer, R&D
Ontario California
Current softener feeds hot water and laundry room cold. When I drop down the new loop for the new softener it will add soft cold to all the main bathroom fixtures as well. Depending on how well soft cold in the main bath sink goes for teeth brushing, I plan on adding soft cold to the half bath toilet and sink. The half bath will be easy to swap out as it's all flowguard gold CPCV from the last copper crisis in the 1980's.....lol. After 30 years it all looks good.
You should be little to no change in the taste of the water for brushing teeth, and there really is no negative. Sounds like you are doing some major piping in your house. If you have plans on installing a tankless water heater, there are some interesting tricks you can do to minimize your saft water needs throughout the house.
80's copper pipe prices, I just started my water treatment career at the end of that huge spike, the company I started with was very good at using as little copper as possible, and saving every scrap piece for recyclying. We made a lot of money with the recycling copper and brass, that paid for the company parties, ping pong table, etc. When the price dropped again, the recycling almost became a waste of gas to drive it to the recycling center.
FleckLander
Wisconsin
The 7000SXT arrived early this morning with the neighbors early AM UPS next day air stuff. I wasn't that impressed with the packaging of the resin tank. Just a two piece tight fitting box with no collars around the resin tank or anything. Distributor tube was just rolling around loose inside the tank. Is this normal? Resin tank was also a Clack made in Wisconsin. How does it compare to a USA made Structural or Enpress?
Valve is definitely made in USA, has the Pentair Asembled in USA sticker on it with what looks like 031512 assembly date. Sticker has BLFC: 0.5 GPM, DLFC: 2.4 GPM, and Injector: 2. This doesn't jibe with what the Fleck Performance Bulletin No. 599 recommends for a 12" tank, so I pulled the DLFC, BLFC and injector cap. Injector is white which makes it a #1 I believe? BLFC has "50" on the washer which I assume is 0.5 GPM? DLFC has "350" on the washer which I assume is 3.5 GPM? What's up with all this? Based on the Fleck bulletin I might have problems with brine draw or refill with this combination. This softener was purchased from an online dealer who also said that they had 50 years of experience in their retail store. And I almost forgot the best part. They indicated that their 7000's came with a 32 mm distributor. It looked kinda small so I measured it. Definitely only a 1" tube. So now I've got the dang 1" adapter too. Just because I asked for an upper basket I shouldn't have gotten a 1" distributor also? I can probably live with the 1" distributor, but I think I might have to make a change in the BLFC at least. Any recommendations?
PS: The sold to and ship to on the valve box was to Enting Water Conditioning. Is this a wholesaler?
ditttohead
Ontario California
FleckLander
1: The Clack tanks are fairly good, I would have no problem with them. I prefer the Structural, but the reason is too long and detailed to go into. To keep it simple, if a warranty issue ever comes up (extremely rare) the Structural is easier to deal with. Regardless, your odds of needing warranty service on a good quality tank are extremely remote, so no worries.
2: manifold rolling around in the tank... normal, we usually ship them with a foam piece to retain it, but I dont see any damage occuring.
3: You are correct on the bulletin, that is our 7000 cheat sheet since that information is not posted in any of the manuals. The #1 injector is not technically compatible with the .5 BLFC. The 7000 series controller refills the brine tank with soft water. The water flows through the injector during refill, the Brine line flow control is supposed to regulate the refill rate, if their is a mismatch, the refill will be regulated by the injector. They should send you out the proper injector and BLFC for the 12" tank. #0 red and .25 are the normal combination, a .125 BLFC is also acceptable. I will post the programming guide for this valve tomorrow for the .125 and .25 injectors. The #1 injector would be ok, but since you want this done perfectly, you may as well do the injector too.
4: The Drain line flow control button should be a 3.5 for a 12" tank, unless your water is excessivley cold or warm.
5: 1.05" vs 32MM, hmmm, they should have shipped the 32MM if they said they would supply that. The 32mm manifold assembly is considerably more expensive. It also eliminates an o-ring/adapter in the bottom of the control valve. Take a look at the bottom of the control valve where the manifold inserts, if they did it right for the 1.05" manifold, you will see an adapter inserted into the bottom of the valve which adapts the valve from 32mm to 1.05". This part is not removable, if you try to do that, you will break the valve. Once the valve is adapted to 1.05", it stays 1.05". that being said, you will not notice a differencein flow between the 2 sizes on that small of a system.
6: Upper basket, the 32mm is a standard upper basket size. Ordering an upper basket... they should have shipped the 32mm...
7: Enting water conditioning, a great company with a great staff. Yes, they are a wholesaler. And, the company should have blind drop shipped the system so Enting would not show up anywhere. Oops.
FleckLander
Wisconsin
Thanks dittto for confirming my suspicions on what I thought bulletin no. 599 was saying.
After a little googling and comparing shipping addresses and domain registrations, it looks like Enting also operates a retail storefront and an online storefront under a different name that I bought my softener from. I bought from them because they indicated they had the unit in stock in their warehouse and they actually answered questions and gave an opinion on the 7000. They were also $24 cheaper than a competitor, but the competitor definitely offered a Fleck 32 mm distributor and upper basket and a Structural branded resin tank. I didn't try to take advantage of their low price by requesting free gravel, because I can get gravel from a local dealer for like $5, cheaper that their shippping cost on it probably.
My valve has definitely been changed from the specs on the valve sticker. Sticker says injector 2 and I definitely have a white #1 injector, assuming a #2 blue injector wouldn't have a white top on it visible when I pulled the injector cap? Valve sticker definitely says DLFC 2.4 GPM. I take it that the "350" on the DLFC washer indicates that it is a 3.5 GPM DLFC that I have?
After reading horror stories on here, the first thing I checked after measuring the distributor tube at 1.05" was that the 1.05" adapter was on the valve. It's definitely there. I realize that the injector and BLFC can be easily swapped out to the manufacturer recommended #0 and .125 or .25. Switching to the 32 mm distributor is going to require shipping the valve back. Would I be a jerk for requesting what they said they would ship in their email and that what the valve actually has is the same as what the valve sticker says it has? The changed injector and DLFC gives me a feeling that my valve might have been a return or something. I think I better dig out my feeler guage set to make sure that I don't have a fine mesh distributor and upper basket too. I'll be sending an email back to the seller regarding these questions after I confirm that question on the "350" on the DLFC washer = 3.5GPM. I just want to make sure I know what I'm talking about before I get back to them......lol.
PS: Does the S/N ******X-031512-0006 indicate my valve was assembled on 03-15-2012?
ditttohead
Ontario California
Your research and effort you have put into this purchase should be applauded. I appreciate it. You have done more homework than many of the people who sell equipment.
Regarding the valve being a return, it is probably not. The specs you say were on the valve match up to the way many distributors have ordered their valves in the past, without realizing the conflict in the injector/BLFC size. Most companies specify the valve to their liking, IE: injector, BLFC, DLFC, and even preprogrammed (flashed ROM) so that the majority of their valves can go out the door without even the need for programming. When we fill orders or build units, we change the injector, BLFC, and DLFC to match the system design (tank, media, etc.). We can even change pistons, brine cams, etc. to match the system design. I highly doubt your system is a return, but they should at least send you out the correct injector and BLFC. it will cost them a few dollars to ship it, but it would be the right thing to do. As to the valve being 1.05" instead of 32mm, you will never notice the difference. If you had a 5 cu. ft. system then you would need a 32mm distributor, but for your application the 1.05" is fine. your real limiting factor will be the restriction through the media, not the manifold.
The only way to remove the 32mm x 1.05" adapter is with a hacksaw blade, a steady hand, and 10 minutes.
Now, the real world information. The injector / BLFC conflict you have will probably not affect the way the valve performs, but it is pushing the limits. This "wrong" configuration has been a common problem for many years and is caused by people not realizing the 7000 refills through the injector. This could cause the system to slightly underfill the brine tank since the injector becomes the flow control instead of the BLFC button. Most people never notice if there is a slight undersalting since the system has some reserves built into it that would hide this potential conflict.
Again, thanks for doing the research.
FleckLander
Wisconsin
I emailed the seller on Friday with a copy of the Fleck bulletin and let them know my concerns about the oversized BLFC and larger injector. I got the impression that they weren't aware of this particular Fleck bulletin regarding the 7000 valve. I found this interesting from someone who touts their 50 years of experience on their website. I checked with an online competitor yesterday who gets critized for not knowing what they are doing sometimes on here. They had apparently read the bulletin as their 7000's were sized with the Fleck recommended injector and BLFC.
I never got an email response from my seller. To their credit, a #0 red injector and .25 GPM BLFC washer did arrive in the mail yesterday, along with my Falcon flexible SS connectors from another seller. To my suprise, the Falcon's were made in China? What's up with this?
ditttohead
Ontario California
I am glad they sent the corrct injector and BLFC. I have attached the programming guide for you if it helps. This is our "default" programming for the 7000. It will work for 90% of applications and will balance salt and water efficiency, and should give you very high quality soft water. The only major change in the programming would be the hardness. Set it to the actual hardness.
Yes, the Falcon Flex lines are made in China. They have been able to maintain control of their manufacturing and have done an excellent job of keeping the quality high. A couple of competitors make similar products in China, but the quality has never been as good as the Falcon.
