Gravy
Two of us live in a 2200 sf house on well water. Salesman says our water hardness is 11. I'm going to get the Hach kit to verify. I'm thinking of buying a system through Abundant Flow. Any comments? Looking at either a Fleck 5600sxt with separate brine and resin tanks, or maybe a cabinet type. Here's the problem: we don't have a basement, and would rather not give up space in the house.
The HW heater and well pressure tank are in the crawlspace, near the entry in the only part deep enough...about 5 ft. There's not much space remaining for a water softener.
Could the resin tank be mounted horizontally? From looking at flow diagrams, it appears not to be a good idea. But someone out there knows. I think the brine tank is only 36" high.
Even standing the resin tank up would be tight, since the head would be right at the joists. Not a good install...
How about the cabinet type? The top of a 32,000 g unit would be 48", maybe leaving me enough room to bucket-fill salt?
If not that, how foolish would it be to put a cabinet unit in a room with no floor drain (overflows, spills...)? I could pipe the drain via standpipe, and other piping, down thru the crawlspace.
Is that the only sensible solution?
