Residential Wiring & Crimp Fittings
Discussion in 'Electrical Forum discussion & Blog' started by seaneys, Jul 22, 2007.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    I'm wiring an addition to my house.. I've been through this a few times in the past (actually rewired my current house a few years ago). I really like to use stranded wire since it is easier to pull (12 Ga THHN). I just find it annoying getting stranded wire around the screw connectors on outlets and switches.
    Is is accepted by code (2005 NEC) to use mechanical crimp lugs in the place of wrapping the wire around the screw connector? I can not find a reference on GB's site stating that they specifically conform to the 2005 NEC...
    Is this a crazy way to attach the wires?
    Thanks,
    Steve
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Yes
    Just leave a little piece (about 1/4 inch) of the insulation at the very end of the stripped end and it will hold the strands together when installing them under a screw
  4. jimbo
    jimbo Plumber
    For receptacles, use the kind that are backwire. NOT back-stabbed. Use the kind where the end of the wire is pushed into an opening on the back, and when you tighten the screw it clamps the wire. Very secure .
  5. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    As long as the crimp on connector is UL listed for attachment to that type of wire you should be fine. If you look in the section that covers THHN/THWN it should say that any listed terminations are acceptable. Don't forget that UL listing requires that you attach per manufacturer's instructions. I've seen this in commercial wire-ups where they didn't use the back-wire (not backstab) receptacles as Jimbo suggests (best option).
Similar Threads: Residential Wiring
Electrical Forum discussion & Blog What is the new year bringing, especially in residential, especially in service panel Jan 5, 2014
Electrical Forum discussion & Blog DIYer's doing residential electrical repairs/installs before Sep 16, 2010
Electrical Forum discussion & Blog Residential Lights and Outlets on Same Circuit? Aug 23, 2010
Electrical Forum discussion & Blog PVC conduit for residential install Sep 8, 2008
Electrical Forum discussion & Blog Dishwasher wiring all of a sudden overheats and melts 52 minutes ago
