Residential vinyl window replacement: Fairfield 70 Series
Discussion in 'Remodel Forum & Blog' started by clearchoicewindows, Oct 30, 2012.
  1. clearchoicewindows
    clearchoicewindows New Member
    Nov 30, 2011
    West Jordan, Utah
    When you need residential vinyl window replacement you should call a company who specializes in this type of services and is capable to do a great job, and give you the best advice when it comes to the residential vinyl window you should choose.
    Fairfield 70 Series residential vinyl windows are stunning inside and out, no matter what your architectural style is. 70 Series windows come in 5 styles that are completely compatible with wood, vinyl siding, even stucco applications. Available styles include: Single-Hung, Horizontal Sliding, Picture, Sliding Patio Door, Hinged Patio Door. Using the latest technology, Fairfield windows deliver sturdy construction and precision-welded frames and sashes along with exceptionally energy-efficient insulated glass. Plus, these windows never require scraping or painting and remain easy to maintain for good.
    Here are the 70 Series features:
    -2-5/8†frame depth and integral nailing fin with 1-3/8†or 7/8†fin setback for compatibility with wood, vinyl and stucco applications
    -A 1-3/8" J-channel and stucco flange option is also available
    -3/4†insulated single-strength glass with warm edge spacer technology for energy-efficiency
    -Integral J-channel
    -Precision-welded frame and sash for strength and energy-efficiency
    -Removable fiberglass screens for easy cleaning.
    When it comes to residential vinyl window replacement also think about their options.
    For Fairfield 70 Series, options include:
    -Low-E glass available for increased energy-efficiency
    -Internal grids in a variety of styles
    -Tinted glass and obscure glass
    -Continuous head and sill for multiple-unit option
    -Factory mulling for easier site installation
    -Fresh air ventilators
    -Available in white, almond and desert clay
    When you choose Fairfield Solid Vinyl Windows from Alside for your residential vinyl windows replacement, you’ll enjoy beauty, performance and strength for the life of your home.
Similar Threads: Residential vinyl
Remodel Forum & Blog Ultramaxx Fusion-Welded Residential Vinyl Windows May 25, 2012
Remodel Forum & Blog Fairfield 80 Series Residential Vinyl Windows May 10, 2012
Remodel Forum & Blog Excalibur II Fusion-Welded residential Vinyl Windows Apr 27, 2012
Remodel Forum & Blog Window repair and residential glasss replacement Jul 19, 2012
Remodel Forum & Blog Wolmanized (pressure-treated) Plywood inside residential areas? Feb 24, 2010
