ta240
Hi,
We are getting ready to redo some of our bathroom and it requires removing and reinstalling a drop in tub that is set inside a raised tiled area. I broke out the small access point on the front that was the last spot they tiled when they built the house and looking inside I see that the tub is sitting on a 2x4 rectangle with 2 sheets of drywall on top of it and then expanding spray foam between that and the tub. One of the foam feet under the tub is sitting about 4" off to the side of all of this with nothing under it.
From everything I've seen this really isn't the way to support a tub and is probably why it creaks when we get in and out of it.
What is the proper way to fill the space under the tub? Right now I'm thinking a taller and wider platform to replace their 2x4 and drywall one that would get it up to right under the feet of the tub consisting of a wooden frame with cross supports in the middle and 3/4" plywood on top. With plastic sheeting then motar then another plastic sheet followed by the tub.
Is that right? Do the foam blocks that are on the tub have to be supported by the frame or is the mortar under the tub enough?
Thanks,
Trevor
Thanks,
Trevor
