Resetting a Concrete Slab
Discussion in 'Lawn Care/Landscaping' started by Kevs02Accord, May 16, 2012.
  1. Kevs02Accord
    Kevs02Accord New Member
    Feb 12, 2012
    Dayton, OH
    Not sure if this is the right form. I found a concrete slab, probably 3x3 almost totally buried by the side garage door. So I dug it up with the intentions to put it back. The question is, how should I reset the slab? How do I lay the base, 2" of sand and 2" of gravel? How high above the ground can the slab be? The main reason is when the slab wasn't there it felt like too far of a drop from the door sill to the ground. I am hoping if I put the slab back this will be an easier transition. My plan was to fill in the hole, add 2" of sand packed down, 2" of small gravel, packed down and then place the slab on top of this, a little above ground level.
  2. Cookie
    Cookie .
    Oct 7, 2005
    Well, I can't answer the whole question, but, I would make whatever, base necessary, to be 6 inches thick, using 3/4 inch stone.
  4. Kevs02Accord
    Feb 12, 2012
    Dayton, OH
    Thanks for the info. I am pretty sure they didn't use 3/4" stone, its maybe a 1/4".
    Can anyone else tell me if I will run into problems with having part of the slab above ground level?
  5. Cookie
    Cookie .
    Oct 7, 2005
  6. Kevs02Accord
    Feb 12, 2012
    Dayton, OH
Similar Threads: Resetting Concrete
Lawn Care/Landscaping hydraulic concrete question Mar 31, 2007
Lawn Care/Landscaping Made a concrete sidewalk today.... Aug 9, 2006
