Rerouting Main Stack / Toilet position
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DYI, Aug 17, 2011.
  1. DYI
    DYI New Member
    Aug 17, 2011
    Vancouver, BC
    I'm expanding my upstairs bathroom and would like to push the wall where the main 3" stack is in over 16".
    Please refer to the attachment to see what I'm trying to achieve. plumbing.jpg
    Can I put the upstairs toilet in the position I've drawn (at the top of the sanitary tee)? Will it vent correctly?
  2. Terry
    Aug 17, 2004
    So many things wrong with that layout.
    Do they really plumb like that in Canada?
    There aren't any codes in the lower 48 that will allow some of what I'm seeing on the drawing.
    I'm not so worried about the toilet, but some of the other fixtures look like problems.
  4. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Yea, you can't do 90% of that, not even in Canada
  5. DYI
    DYI New Member
    Aug 17, 2011
    Vancouver, BC
    Thanks for the useful info. By the way, the layout (except for the upper toilet) has worked for the past 50+ years in the house. What conerns do you have about the other fixtures?
  6. Terry
    Aug 17, 2004
    There is a difference between the phrase
    "Working for 50 years."
    and
    "In use for 50 years."
    The way this is plumbed will siphon water from the traps.
    Yes, the water will move it's way down the line, so will the water in the p-traps.
    The home may smell a bit, but then after 50 years, you start thinking that's normal.
  7. DYI
    DYI New Member
    Aug 17, 2011
    Vancouver, BC
    and
    The home may smell a bit, but then after 50 years, you start thinking that's normal.[/QUOTE]
    Good point. Well, apparently way back then wet venting was all the rage in Canada.
    Anyway, all of the that plumbing is in the slab.
    Is there anyway of adjusting the above slab plumbing to improve the venting issues?
    Would the following changes be sufficient?
  8. hj
    You missed the downstairs vanity. And the toilet vent can connect to the laundry vent 42" above the floor, as long as the upstairs sink connects to the main riser.
Similar Threads: Rerouting Main
Plumbing Forum, Professional & DIY Advice How to fix main water line leak issue-repipeing or rerouting pipes Oct 7, 2016
Plumbing Forum, Professional & DIY Advice Rerouting waste line...is this radius okay? Apr 6, 2016
Plumbing Forum, Professional & DIY Advice Washer Floods Into Kitchen Sink & Rerouting Furnace Condensate Drain Jan 26, 2016
Plumbing Forum, Professional & DIY Advice Rerouting a soil stack Apr 27, 2014
Plumbing Forum, Professional & DIY Advice Rerouting kitchen drain Mar 18, 2014
