Required drain size for double sink and tub
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by boomer70, Sep 13, 2006.
  1. boomer70
    boomer70 New Member
    Sep 13, 2006
    What is the required drain diameter for a double sink (back-to-back) with a tub downstream?
    Thanks for your help.
  2. hj
    pipe
    It depends on how you do the piping, but normally 2".
  4. boomer70
    boomer70 New Member
    Sep 13, 2006
    On the second floor of a two-story house, two lavs are at the beginning of a drain line. They are connected with a double sanitary tee and are branch vented with 1 1/2" pipe to the stack vent. The 1 1/2" drain runs 2-3 feet to the soil stack that serves the second floor. Note that a watercloset drains directly into this soil stack as well and that the soil stack is also branch vented to the same stack vent that the lavs are vented to.
    A tub is being added, and the drain needs to connect to the soil stack without taking too many bends. Can the tub drain connect to the existing 1 1/2" drain line coming from the double lavs?
Similar Threads: Required drain
Plumbing Forum, Professional & DIY Advice What is the minimum slope required for horizontal toilet drain pipe? Apr 21, 2012
Plumbing Forum, Professional & DIY Advice venting required for 2 new basement floor drains? Feb 14, 2012
Plumbing Forum, Professional & DIY Advice Basement floor drain - vent required? Dec 22, 2006
Plumbing Forum, Professional & DIY Advice Washer drain pan required? Jun 21, 2006
Plumbing Forum, Professional & DIY Advice Moen T8360 Transfer Valve Facia - Is the 3360 Valve Required Or Can I Use The 3372 Valve? Nov 11, 2015
