Replacing Well Pump in Western Central FL
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by aquadude, Aug 31, 2009.
  1. aquadude
    aquadude New Member
    Aug 31, 2009
    Bought my home 3 years ago (1992 yr built -so well is that old). I don't want the pump to go out and it's an emergency so I was thinking of having pump replaced.
    Should I try to get three bids (I don't know how deep the well is - the casing material, etc.) or just call someone?
    I don't have anything they could base a price on.
    what should I look for in a contractor?
    Should I even replace it or just let it go till it quits? I hate emergency situations cause then you can be behind the 8 ball.
    THanks for any help.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    That pump could go out tomorrow, or it could last another 20 years. Even if you put in a new pump, you can’t guarantee it will last any longer. When a pump goes out it is always an emergency. If you have neighbors close enough, you can run a garden hose from one of your faucets to one of theirs, and you will have water until you can get the pump fixed. It is always good to have discussed this with the neighbor beforehand. I even keep a couple of hoses and a female to female hose connector hanging in a common area where either of us can get to it. This keeps you from having to get the pump fixed the same day it goes out. This is safer than having a new pump, which could still go out tomorrow, or New Years day.
  4. Gary Slusser
    Retired
    If you don't have any idea of how old the pump is, or can't find out, I'd let it quit on it's own as long as you know where the well is and the well is accessible; meaning not buried "out there somewhere". If you have the casing sticking up out of the ground, remove the cap and see if there is some info written on the underside.
    Otherwise if you want a project now, and have the money, see if you and a buddy or two can replace it yourself.
  5. Rutherfordman
    Rutherfordman DIY Member
    Mar 9, 2009
    North Carolina
    Just one note on running from a hose spigot to another. Many of the newer hose spigots on houses have a backflow preventer which will not allow water to be pumped into the house. Mine is this way. If like mine the backflow preventer (vacuum breaker) is part of the spigot instead of the threaded on type (older) you can run a hose to the washer box cold water connection. Many of these do not have built in backflow preventers. I am fortunate in that I have a valve box at my driveway to serve another property from a community well which is a different well system than mine. We have back fed each other in times of need so this has really come in handy:D
  6. mudpuppy
    mudpuppy New Member
    May 4, 2009
    well drilling, abandonment
    nw florida
    If your well was drilled by a licensed contractor, you should be able to get well completion information from your regional water management district if you are north of Lee County/ Ft. Myers.
    If in Lee, Manatee or Sarasota county, you might be able to get it from the county.
    Charlotte Co to Citrus Co. - SWFWMD - 800 423 1476
    Levy Co to Jefferson Co - SRWMD - 800 226 1066
Similar Threads: Replacing Pump
Pumps and Tanks Well Forum & Blog. Water is life. Replacing existing well pump system Jan 8, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Replacing a jet pump with a submersible pump Jan 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Replacing pump in shallow well Jun 9, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Replacing pump, need help. Jun 17, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Stuck!! LITERALLY replacing submersible pump Nov 28, 2012
