Replacing water heater
Discussion in 'Water Heater Forum, Tanks' started by cag9228, Aug 8, 2011.
  1. cag9228
    cag9228 New Member
    Jul 18, 2008
    Texas
    All,
    I am replacing a water heater that developed a slight leak at the cold inlet. At first I thought it was the nipple, but after disassembling and reassembling the connections (used Rectorseal #5 on the threaded connections) I realized it was a leak on a weld.
    So when installing the new one, do they come with the T&P already installed? If so, do I need to remove it, dope it, and screw it back in? Ditto with the nipples. And should I be worried about over tightening threaded connections?
    Regards,
    Andy
  2. Terry
    Aug 17, 2004
    Most new water heaters that I'm installing have the T&P and the nipples preinstalled.
  4. cag9228
    cag9228 New Member
    Jul 18, 2008
    Texas
    Ah ok. So then I just leave them alone.
    I'll attach the dielectric unions to the nipples and run copper from the unions up. That's pretty easy.
  5. jadnashua
    Depending on the one you buy, the nipples may already BE a dielectric union...no reason to add another one. Also, depending on where you live, some places REQUIRE the connection to be made with a flexible supply, and some PROHIBIT it. It's much easier to screw the flexible copper supply pipe in rather than try to align it with hard copper, but either can work, depending on what your inspector wants.
  6. cag9228
    cag9228 New Member
    Jul 18, 2008
    Texas
    Yeah the flexible connectors are out as an option due to code. Aligning the copper isn't that big of a deal.
Similar Threads: Replacing water
Water Heater Forum, Tanks Replacing Solar Hot Water Tank Jan 10, 2017
Water Heater Forum, Tanks Need Advice Replacing a 1987 Water Heater Oct 26, 2016
Water Heater Forum, Tanks Replacing Grommet Seal on Hot Water Heater Jul 25, 2016
Water Heater Forum, Tanks Advice replacing old water heater Jun 25, 2015
Water Heater Forum, Tanks Replacing a power vent water heater Mar 29, 2015
