Replacing Vinyl flooring with Tile in bathroom and have toilet question
Discussion in 'Toilet Forum discussions' started by 91Aggie, Dec 3, 2009.
  1. 91Aggie
    91Aggie New Member
    Nov 12, 2009
    Texas
    We are replacing the vinyl flooring in our bathroom with tile.
    Here's the plan:
    1) Take toilet out (I know how to do this).
    2) Put tile down.
    3) then put toilet back in.
    My question is on part #3. Will I have to do anything complicated since the tile will put the toiler up a little higher than when it was sitting on the vinyl?
    Or will the wax ring make up that slight difference in height?
    I've read about and seen videos on replacing toilets, but nothing on the internet I can find talks about this particular issue, so I want to make sure I don't need to anything with what is currently attached to the concrete floor.
    Thanks in advance.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Ideally, your flange should sit on or at the level of the tile, if necessary it can work with the top of the flange level with the tile. Any lower and you can have issues.
  4. 91Aggie
    91Aggie New Member
    Nov 12, 2009
    Texas
    So, can that flange be easily raised?
    Is this a major plumbing job, or something a DIYer can do relatively painlessly?
  5. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    There are extension rings that can be added to bring the height of the flange up. DIY is fine in 99.9999% of the jobs as long as the original flange is in good condition.
  6. 91Aggie
    91Aggie New Member
    Nov 12, 2009
    Texas
    Thanks for your fast response. I think that confirms what I've found since posting here (adjusted my Google search and found some other sites that talk about this issue).
    Feeling much better about this now!
  7. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
  8. 91Aggie
    91Aggie New Member
    Nov 12, 2009
    Texas
    Thanks... My brother (who owns a Ceramic Tile installation business) is doing the actual tiling, so I've got that under control! :D )
  9. Terry
    Aug 17, 2004
    If the flange is low, it may take two wax rings, or something like a Fluidmaster Waxless seal.
    If you use the Waxless seal, it pushes on the bowl first.
    [​IMG]
    If you use the Fluidmaster waxless seal, push it onto the bottom of the bowl first.
Similar Threads: Replacing Vinyl
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Feb 15, 2017
Toilet Forum discussions Toilet running randomly even after replacing flapper Feb 7, 2017
Toilet Forum discussions Replacing Toto Ultimate round bowl, 14" rough in - no knee room Jan 21, 2017
Toilet Forum discussions Replacing the lower seat on a Bio-Bidet Jan 14, 2017
Toilet Forum discussions Trouble replacing valve in minimal clearance skirted toilet Dec 4, 2016
