Replacing Thermal Expansion Tank
Discussion in 'Water Heater Forum, Tanks' started by zaedrus, Apr 12, 2010.
  1. zaedrus
    zaedrus New Member
    Apr 12, 2010
    indianapolis
    Howdy!
    I'm replacing my 2 gal. thermal expansion tank due to a pin hole leak.
    I've charged the new one per the mfr's directions.
    When I went to pull the old one off, it wouldn't budge.
    I just used a wrench on the hex end of the pipe, and another wrench on the hex of the tank.
    I'm afraid of using too much force and busting the pipe it hangs on.
    Any tricks I might try?
  2. hj
    If you grab the pipe properly, it will NOT break off no matter how much force you apply to the tank.
  4. zaedrus
    zaedrus New Member
    Apr 12, 2010
    indianapolis
    Heheh... this begs the question - what's the right way, and what are the many wrong ways? Thanks for the input!
  5. jadnashua
    You may need two wrenches...hold the one wrench on the threaded T while using the other one on the tank. the goal is to prevent excess torque on the pipe and fitting. I've only replaced a couple, but they spun off without tools without problems. Teflon tape verses pipe dope may make that easier when the time comes, or both.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Mmmm great advice! Tasty Fried Spam Sandwiches...
    [​IMG]
  7. gabby
    gabby New Member
    Oct 12, 2011
    s.c.
    I bought a new expansion tank but it had no direction in it. It was the last one they had at HD an it had been open. Do these things need a charge per the mfr's directions?
    Also mine is full of water so it is going to be a mess when I remove it. At present it is laying over on its side full of water. I guess the bladder inside must have gone bad.
  8. gabby
    gabby New Member
    Oct 12, 2011
    s.c.
    Is there no pressure on these things when you remove one of them? Sort of scary removing it.
    Mine is laying over on its side full of water.
  9. Terry
    Aug 17, 2004
    When you turn off the water and open a hot tap, that will relieve the pressure.
    The pressure in the tank should match the incoming water pressure.
Similar Threads: Replacing Thermal
Water Heater Forum, Tanks Replacing Thermal Expansion Tank Feb 7, 2009
Water Heater Forum, Tanks Replacing Check Valve Mar 29, 2017
Water Heater Forum, Tanks Replacing Solar Hot Water Tank Jan 10, 2017
Water Heater Forum, Tanks Need Advice Replacing a 1987 Water Heater Oct 26, 2016
Water Heater Forum, Tanks Heater does not kick in after replacing heat exchanger Aug 29, 2016
