Replacing tank on vfd
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by greenmonster304, Mar 2, 2012.
  1. greenmonster304
    greenmonster304 New Member
    Apr 16, 2011
    Hampton Bays, NY
    The tank for my vfd started to leak so I want to replace it but I am not sure what pressure to charge the new tank to. I wasnt sure if the vfd tanks get charged differently. Thanks in advance for your help.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The tank precharge is usually about 30% less than the running pressure.
  4. JPat
    JPat New Member
    Mar 5, 2012
    Johnsburg, Il
    Hmmm. Every VFD we have installed, the manufacturer recommends 70% air pressure to running pressure...Doing the math for you; if your running pressure is 60psi the pre-charge in the tank should be 42psi.
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    Hi JPat. Doing the math I think 70% of, or 30% less than 60 is still the same 42 PSI. The real question is why did the tank go bad?
  6. JPat
    JPat New Member
    Mar 5, 2012
    Johnsburg, Il
    Meh, tanks go bad all the time. The rubber that most companies are using is recycled... "Do it yourself" tanks have a high failure rate as well. 5yr warranty on all tanks!!!
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    Bladder or diaphragm type tanks only go bad for two reasons. Either they rust through, or the bladder breaks. Most of the busted bladders I see on tanks with a VFD, are from the pump not shutting off when it should, causing the pressure to spike and bust the bladder.
    One of the big box stores has a 32 gallon tank with a lifetime warranty. I guess it doesn’t have recycled rubber.
  8. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    "Lifetime warranty"...when it breaks, the life is over!!
  9. greenmonster304
    Apr 16, 2011
    Hampton Bays, NY
    The tank rusted out because it was in a pit that was always damp.
  10. valveman
    Mar 15, 2006
    Lubbock, Texas
    Good to know. These are the kind of installations that can benefit from a fiberglass tank.
    Yeah "lifetime warranty". Can you believe that? I think the company might just change names every few years to get out of warranties. :)
Similar Threads: Replacing tank
Pumps and Tanks Well Forum & Blog. Water is life. Need advice about replacing Wellmate Pressure Tank Apr 6, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Replacing Flange Cover on Pressure Tank. Mar 10, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Replacing old submersible pump/pressurizing tank vs constant pressure system Jan 9, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Replacing well tank question Jun 8, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Replacing 25yr old captive air tank Apr 20, 2010
