Replacing sink drains
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Alpinist, Jun 21, 2010.
  1. Alpinist
    Alpinist New Member
    Jun 21, 2010
    Ridgway, CO
    I am grateful for your advice, so thanks for providing this awesome forum!
    I have an older Kohler double basin, cast iron sink I'd like to put in my kitchen. Caveat is that one drain is designed for a disposer. Is it possible to replace the stainless steel drain unit with a standard drain like the one on the other side, or should I just get a different sink?
  2. Terry
    Aug 17, 2004
    The drain holes on the sink are the same standard size.
  4. Alpinist
    Alpinist New Member
    Jun 21, 2010
    Ridgway, CO
    But is it possible for me to remove the one already installed in the sink that is for a disposer and replace it with one that is standard? That looks tricky and I'm unsure if I can get it off or not. Not obvious how to remove it. Thanks for any tips if it's possible!
  5. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
  6. Alpinist
    Alpinist New Member
    Jun 21, 2010
    Ridgway, CO
    Thanks Shacko! I figured it out with some fiddling. Turns out mine had a metal ring holding it all together that I was able to remove with a pair of needle nose plyers. Your link worked and was just what might have helped me had I not figured it out earlier.
Similar Threads: Replacing sink
Plumbing Forum, Professional & DIY Advice Help Replacing Washer and O-ring on Leaky Bathroom Sink Handle Jul 15, 2016
Plumbing Forum, Professional & DIY Advice Noisy sink drain after replacing dishwasher Mar 18, 2016
Plumbing Forum, Professional & DIY Advice Replacing double with single sink Aug 15, 2015
Plumbing Forum, Professional & DIY Advice Replacing under sink, sweated, water shutoff Oct 7, 2014
Plumbing Forum, Professional & DIY Advice Need help replacing bathroom sink Sep 10, 2013
