Replacing Sewer Drain Cap in Basement Floor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LFM, May 4, 2008.
  1. LFM
    LFM New Member
    May 4, 2008
    Fire Alarm Tech
    S.E. Michigan
    I am wondering if a Wheeler # 527 Pipercuttering tool is the best way to cut the sewer steel pipe that is in the basement floor? The sewer line that has the cleanout has the threads missing and no longer allows the drain to be capped off. I have attempted to cut this metal pipe with a sawzall but it barely scratched the surface of it after using two metal cutting blades.
    Can someone help with how a Wheeler Pipecutter works and will it cut this pipe or is there a better tool to do this for a homeowner to use. It is a 4 inch pipe with a hub just above the cement floor and would like to get this project done. Seems there is little information on these tools or even what this metal pipe is made of. It must be very hard being a sawzall did nothing to it.
    What will I need to replace it being I am going from the metal pipe to a plastic pipe being it will be two different materials and sizes will be different? Do they make a "Mission Coupler" that will fit the metal pipe as well as fit the pvc pipe and will it be tight enough to be able to tighten and loosen the clean out cap being they seem to get locked in place?
    Any information would be helpful. I have broken up some of the cement floor around the pipe but trying to only open the floor large enough to get a tool in to cut the metal pipe.
    Thanks in advance for any info...
    Mike / LFM
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    There are cleanout caps that are often used to seal a cleanout that has no threads left. A "Lead Fit-All" or a "Test Plug" could be used. No pipe cutting or, floor breaking is required!
  4. LFM
    LFM New Member
    May 4, 2008
    Fire Alarm Tech
    S.E. Michigan
    I had thought about that but the threaded section is missing about 1/3 of the threads on one of the sides and it is tough to get anything down far enough to seal it off. Any time you run water flush the tolietyou hear it in the basement especially when you are near this clean out pipe. Just thought it would be a good idea to get it capped off.
    That is why I was wondering about this pipecutter I read it in a home repair book but the book was a few years old and I look for this one online and found little information even on their website. They call it a soil/pipecutter but nothing on a 527. I just was wondering if there are any other tools that will cut this pipe. I have the floor already broken up around the pipe that was easy just need to find a tool that can cut this kind of pipe.
  5. LFM
    LFM New Member
    May 4, 2008
    Fire Alarm Tech
    S.E. Michigan
    Still looking for some information on how to cut this pipe???
    Thanks,
    Mike / LFM
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Why don't you post a picture of what you are trying to fix here...
    I'm not convinced you need to cut the pipe!
Similar Threads: Replacing Sewer
Plumbing Forum, Professional & DIY Advice Replacing 1m length of sewer pipe with suspected cement blockage Jun 30, 2013
Plumbing Forum, Professional & DIY Advice Replacing Cast Iron Sewer Line (Pittsburgh Area, PA) Feb 19, 2013
Plumbing Forum, Professional & DIY Advice replacing cast iron sewer pipe Sep 5, 2012
Plumbing Forum, Professional & DIY Advice replacing Cast Iron Stack with Pvc to Clay Sewer pipe Sep 4, 2011
Plumbing Forum, Professional & DIY Advice Replacing old cast Iron sewer pipe with new Jan 5, 2009
