noviceplumber
- Messages
- 7
- Reaction score
- 0
- Points
- 0
I wanted to replace my old washer style shut off vale with a ball valve. The old shut off valve sits on 3/4 piping and is threaded on. On the left it is attached to the feed for the hot water heater and also to the house cold supply. On the right it is attached to the water meter couplings which I think are brass since they are darker than the remainder red copper. The brass couplings attach to the shut off valve via the threaded connection and to the meter via the coupling nut and I am guessing some sort of washer underneath?
My question is, can I remove the shut off valve myself or am I better calling a plumber. In other words anyone who has experienced this replacement have you had success with this type of repair?
Thanks in advance!
PS: There is another "main" shut off before the water meter further on the right so I could probably shut off the water there. Note this the same style washer type which leaks each time at the compression nut when I overdo opening and closing it.
Thanks in advance!
