Replacing Plumbing System on Well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by statjunk, Jul 29, 2011.
  1. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    Hello All,
    It's been a while since I've been on here. I'm hoping I can get some assistance with a project. I bought a vacation home up north and I'm going to convert the hot water tank over to gas from electric. Simultaneously I'm going to move the hot water tank from the first floor down into the basement right next to where the water enters the basement. The expansion tank is very large and it's going to be replaced with a smaller bladder type unit and moved into the basement also. I'm also going to add a particulate filter, taste & odor filter and a water softener.
    I know a couple of things. One the water is hard. I had it measured there is no iron but there are 25 parts hardness. The scale I was shown when measured says that anything over 20 is very hard. The water tastes fine. I also know I have a submersible type pump. I don't know anything else. So if there is something I ought to know please advise and I'll figure it out.
    The link below is a diagram of the new system I'm looking to install sometime before winter. Please let me know if I'm missing anything here or if I should do anything differently. I tried to re-size the file but was unable to. That is why I provided the link.
    http://i213.photobucket.com/albums/cc318/statjunk/LLWCPlumbingDesign.jpg
    Thanks
    Tom
  2. statjunk
    Jun 28, 2007
    Is there a reason I'm not getting any feedback on my question? Is it not clear?
    Thanks
    Tom
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I can't help you much with water quality. And I can't see your diagram very well. My questions would be; What kind of pump controller? Where is the pressure switch? You mean pressure tank not expansion tank?
Similar Threads: Replacing Plumbing
Pumps and Tanks Well Forum & Blog. Water is life. Replacing existing well pump system Jan 8, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Replacing a jet pump with a submersible pump Jan 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Need advice about replacing Wellmate Pressure Tank Apr 6, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Replacing Flange Cover on Pressure Tank. Mar 10, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Replacing well riser from iron to PVC Jan 26, 2015
