Replacing one-piece form-factor shower and tub
Discussion in 'Shower & Bathtub Forum & Blog' started by bshanahan, Mar 15, 2007.
  1. bshanahan
    bshanahan New Member
    Mar 15, 2007
    Hi there, I am interested in replacing my one-piece plastic form shower and tub. It was the rage in the mid to late 80's but is cracking in spots now. What is the best way to remove the old liner and replace it with real tub.
    Thanks,
    -B
  2. jadnashua
    You'll have to remove some of the drywall around it to reveal the edges. Unscrew it or pull out the nails. Disconnect the fixture and drain, then you should be able to drag it out. BUT, I'd take a sawsall and cut it into more manageable sized pieces. In nearly all cases, the one piece systems are put in place once the house is closed in and before most framing is done - they are just too unwieldy to try to maneuver into place otherwise. Make sure you don't cut any wires or pipes in the demolition process.
  4. jimbo
    jimbo Plumber
    Sawzall.
    And plumbers do not use the term "form factor"!!! That is for engineers and architects.
  5. bshanahan
    Mar 15, 2007
    I guess I should have selected another term. How about all-in-one?
  6. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    I have heard module used quite a bit.
  7. bshanahan
    Mar 15, 2007
    I like the sound of that. The "All-in-one-form-factor module"!
Similar Threads: Replacing one-piece
Shower & Bathtub Forum & Blog Replacing Bathtub Jan 6, 2017
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
Shower & Bathtub Forum & Blog Replacing tub valve set: which side of the wall to work from? Nov 10, 2016
Shower & Bathtub Forum & Blog Replacing shower drum trap Oct 21, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
