Replacing old toilet - rough in location?
Discussion in 'Toilet Forum discussions' started by reh577, Oct 17, 2011.
  1. reh577
    reh577 New Member
    Oct 17, 2011
    Bay Area
    We'd like to replace an old toilet with a Toto Eco Promenade CST423EF(G). Measurement from the wall to the closest set of bolts is 11", but the bulge in the toilet profile (rough out location??) is further forward. Would the Promenade fit in this space?
  2. jadnashua
    I don't know enough about that toilet to tell you which is the set of bolts that actually go on the flange...you'd have to remove it to see. 11" would not be enough for a Promenade, but if the forward ones are the ones attached to the flange, it looks like it may be a 14" rough-in. I think the Promenade is one of those that uses the Unifit adapter, and if so, and it's 14", you'd need to also buy the 14" Unifit adapter otherwise, the toilet would sit out away from the wall (which won't hurt the toilet, but you may not like it!).
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    The rear bolts go to the closet flange. The front bolts are closet screws that are fastened to the floor.
    John
  5. Terry
    Aug 17, 2004
    You measure from the wall, not the floor mold. So you may have a little more then 11" if you are measuring low.
    The drain is centered between the back set of bolts.
    The Promenade needs 11-1/4"
Similar Threads: Replacing toilet
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Feb 15, 2017
Toilet Forum discussions Toilet running randomly even after replacing flapper Feb 7, 2017
Toilet Forum discussions Trouble replacing valve in minimal clearance skirted toilet Dec 4, 2016
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
Toilet Forum discussions Replacing toilets Jun 4, 2016
