Morgana Rue
My old faucet was filthy. After I cleaned it, it began leaking terribly. Truly one of those times where the dirt was holding it together. (Literally, a crack in a sleeve inside was filled with hard water deposits which kept it from leaking) I've temporarily fixed it with some gorilla glue and by letting the deposits build back up, believe it or not, but I know it needs to be replaced. I've replaced a few faucets in the past, but they all had rubber gaskets and no sealant was required.
To replace this faucet, I bought a Pfister "Shelton". (Single mom on a tight budget here) The thing is, the faucet came with a two piece deck plate. The chrome piece and a hard plastic piece that sits under it. The man at Lowes told me that silicone was all I needed. The instructions say to use plumber's putty. I have both. But the instructions didn't specify as to what type of putty. (Regular or Stain Free)
After reading multiple forums from multiple sites, I still can't decide which I should use. On one side is the argument that the putty will destroy the plastic because it is petroleum based and silicone is the ONLY thing to use. On the other side is the argument that they've used the putty for ___ years and NEVER had a problem so putty is the ONLY thing to use.
I've read some pretty heated discussions on this topic, so I DO NOT want to start an argument with this. (Please) What would be great is if you could share your experiences using putty and silicone. Which was easier in your opinion? Have you ever removed a faucet with a plastic deck plate on which putty had been used? Did the plastic crumble? If I ever have to change the faucet again, which is easier to deal with? If I need to stick to silicone, is the type I have okay? It's GE Kitchen/Bath/Plumbing 100% Silicone, Clear. If I need to stick to putty, is they type I have okay? It's Oatey brand. Just regular, basic, plumber's putty.
Thanks in advance!
Thanks in advance!
