replacing main, expansion loop?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Seattle38, Jul 28, 2010.
  1. Seattle38
    Seattle38 New Member
    Jul 26, 2010
    Seattle, Washington
    I'm in Bothell, WA, currently replacing the main between the meter and house. I plan to use type L soft copper, probably sleeved with some closed cell foam.
    The run is about 70ish feet, with a couple of bends; up a rise and around the foundation. Is an expansion loop necessary? or will the bends take up any expansion and contraction?
    Any recommendations on a place to get a 100 foot roll of type L soft at a reasonable cost?
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I wouldn't put in an expansion loop.......
    Not sure where to buy the copper down there but you'll probably end up paying $450-$500 for 100' of type 'L' soft copper while you'd pay about $100 for 100' of 3/4" pex....
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I would go with 1" PVC. 3/4" copper over that much distance will lose too much pressure and flow due to friction, and 3/4" PEX is smaller inside diameter than copper so the loss would be even greater.
  5. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    If his PRV is in the house and he has high pressure going through his main line then he shouldn't have anything to worry about.
  6. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    I would use PE
  7. hj
    Under 100', I would use copper since it does not need joints like PVC would. No comment on using PEX, because I would not.
  8. Seattle38
    Jul 26, 2010
    Seattle, Washington
    I've looked into all the options; I don't want any joints and I don't want plastic. The wife has a wicked sense of taste and the last thing I need after installing a new main is "babe, the water tastes funny."
    Avoiding that is worth the extra $$. I plan on using 1", not 3/4.
    Now, just trying to figure out how to best protect the pipe from rocks and roots etc. I plan to wrap it with closed cell insulation and bed the main in sand. Any other thoughts??
    I think I found a pretty good deal online for 100' of one inch type L, $385
    http://kscdirect.com/item/L+COIL+1X100/JOHN+M+FREY+COMPANY_1+X+100+FT+COIL+TYPE+L+COPPER+TUBE%0A
Similar Threads: replacing main
Plumbing Forum, Professional & DIY Advice Replacing a main shut-off Jun 15, 2014
Plumbing Forum, Professional & DIY Advice Help Replacing 1" Main Water Shut Off Valve May 20, 2013
Plumbing Forum, Professional & DIY Advice replacing shower body--what does "supply building with main shutoff valve" mean? Oct 2, 2012
Plumbing Forum, Professional & DIY Advice Replacing main water line in Arkansas Nov 27, 2011
Plumbing Forum, Professional & DIY Advice Replacing Main Water Supply Line Jul 9, 2011
