Replacing lines on hwt
Discussion in 'Water Heater Forum, Tanks' started by billyh, Mar 10, 2011.
  1. billyh
    billyh New Member
    Feb 5, 2011
    Ontario
    I am 99% sure of this but just in case there is a way around it...
    Can I replace the lines on a hwt without draining the entire tank?
    I am assuming not because it's under pressure... but thought I would ask anyhow.
  2. Terry
    Aug 17, 2004
    Turn off the water and open some faucets.
    If it's electric, turn off the breaker first.
    You only need to drain the tank below the connections, and if those are on top, not even then.
  4. hj
    It is only under pressure until you turn off the water supply and open a faucet. As long as what you are doing is above the water level in the tank, it will NOT leak water out.
  5. billyh
    billyh New Member
    Feb 5, 2011
    Ontario
    Thank you. I had to replace both the lower line (near ground) and the one on the top. So, I ended up draining it.
    Your answers definitely made this easier! Thank you.
Similar Threads: Replacing lines
Water Heater Forum, Tanks Replacing Solar Hot Water Tank Jan 10, 2017
Water Heater Forum, Tanks Need Advice Replacing a 1987 Water Heater Oct 26, 2016
Water Heater Forum, Tanks Heater does not kick in after replacing heat exchanger Aug 29, 2016
Water Heater Forum, Tanks Replacing Grommet Seal on Hot Water Heater Jul 25, 2016
Water Heater Forum, Tanks Advice replacing old water heater Jun 25, 2015
