replacing lead bend
Jim Mills
nebraska
Sorry for the poor drawing. Need to replace this lead closet bend & lav drain without doing any demo to the tile floor. Existing lead line to lav is set on top of joists & burried in mud floor. I have two possible solutions.
Red line represents wye off of cast for lav drain.
Green line represents using high heel elbow.
Both options would include replacing sanitary tee & tying into existing galvanized vent above it.
Bill Shack
30years plumbing 10years plumbing inspector
Montreal Quebec Canada
That is very old way of doing a powder room. Back then you had to do a wipe lead joint to make the connection on to the lead bend. It has been out of the code books for almost 60 years but still legal if it is existing. Remove it and install the y
Jim Mills
nebraska
How about plumbing as it originally was using a 4 X 4 x 2 sanitary tee?
Jim Mills
nebraska
Oops, that last drawing doesn't make any sense. That is not a lead San tee. I'm just wondering if I can tie in to the vertical 4" line like the drawing shows, and how close the the closet flange the side inlet can be? thanks!
