Replacing Kitchen Faucet Pull-out Hose
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by scuba415, Nov 26, 2011.
  1. scuba415
    scuba415 New Member
    Oct 13, 2011
    San Francisco, CA
    Hi All,
    I have an older Delta kitchen faucet with a pull out handle with a leaky hose. The leak is about two inches from the pullout handle side, and is leaking right out of the flexible joints of the hose. I intend to replace the hose. Can someone please give me a few pointers on the procedure, as I have never done this before?
    The end that attaches to the pullout handle looks simple enough, but under the sink where the other end attaches to the base of the faucet there is some type of clip that I am not familiar with, it is plastic and rotates freely. Also, should I be trying to attach the new hose from under the sink, or should I remove the faucet base from the counter top to get more access? It seems like it will be pretty tight trying to reach the clip at the faucet base end from under the sink. Are there any parts or special tools I might need other than the new hose? Will I need a basin wrench or does the pullout hose have a quick clip attachment?
    Attached are a couple pics of the leak and the under sink attachment. leak.jpg under sink.jpg
    TIA
  2. jimbo
    jimbo Plumber
  4. hj
    YOu put your finger between the two "prongs" and spread them apart while pulling on the hose. You do NOT need any tools. Pull the hose out of the faucet, slide the new one down and reinstall the clip after shoving the hose in as far as it will go. When those hoses break it is ALWAYS in that area. I have fixed many hoses with leaks like that, but it is not a DIY task.
  5. scuba415
    scuba415 New Member
    Oct 13, 2011
    San Francisco, CA
    Jimbo,
    Thanks for the link to the diagrams that is my model.
  6. scuba415
    scuba415 New Member
    Oct 13, 2011
    San Francisco, CA
    Thanks for the reply hj,
    I haven't tried to take it apart yet because I don't have the new parts yet, but will follow your advice. Why do you say it is not a DIY task?
    Thanks,
    Steve
  7. jimbo
    jimbo Plumber
    REPLACING it is DIY. hj said he can REPAIR the hose, which is apparently a gift from the plumbing god, because no other plumber in their right mind would try that!!
  8. hj
    quote; which is apparently a gift from the plumbing god, because no other plumber in their right mind would try that!!
    It is a lot faster, cheaper, and more convenient for the customer, for me to repair it than charge them for a new hose, or wait for Delta, (Grohe, Hansgrohe, Moen, etc.), to send them one and then call me back a second time to replace it. THEN, I call the manufacturer and have them send the replacement hose for use the next time it breaks. It is the same "gift" that lets me repair Delta tub/shower valves that homeowners, and other plumbers, have twisted off in the wall.
Similar Threads: Replacing Kitchen
Plumbing Forum, Professional & DIY Advice Replacing Old Kitchen Faucet - Putty or Silicone Jun 14, 2016
Plumbing Forum, Professional & DIY Advice Very low water pressure after replacing kitchen faucet and no hot water in shower May 15, 2014
Plumbing Forum, Professional & DIY Advice Help replacing hose on unknown kitchen faucet Mar 25, 2014
Plumbing Forum, Professional & DIY Advice Replacing Kitchen DWV Under Window Dec 13, 2013
Plumbing Forum, Professional & DIY Advice Replacing Kitchen Faucet Apr 10, 2012
