Replacing hot water baseboard heating
Discussion in 'HVAC Heating & Cooling' started by Serendipity, Feb 16, 2007.
  1. Serendipity
    Serendipity New Member
    Feb 16, 2007
    Our old, battered, chipped and rusted hot water baseboard heaters have got to go! As far as I can see, the pipes and fins are fine and the units operate with no problem. Is it possible to replace just the metal unit surrounding the pipe and fins? I took off the front cover, but the rest of it seems to be embeeded into the wall. Is it possible to somehow pull this out without removing the whole unit?
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    The covers are normally just nailed/screwed to the wall. You'll have to better describe the details of "embedded", or better yet, post a picture.
    The big boxes and plumbing supply houses sell "empy" covers for just the thing you want to do.
  4. Serendipity
    Feb 16, 2007
    I don't have a pic at the moment, but it looks like they installed the baseboard, and then drywalled (actually, mud and lathe) directly above it so the baseboard is slightly recessed (maybe 1/4") into the wall. Nice that it doesn't still out too far into the room but will be a PITA to try to pull out just the dummy cover without disturbing the pipe and fins. Is it even possible to do this or do I just call an HVAC guy to replace the whole unit?
  5. hj
    It sounds like it will be a PITA to remove them, and then you need a new cover with the same dimensions. The pipe supports on the cover will also cause you grief when you try to get them out of the way so the cover will slip off, not to mention the problem trying to get the new ones between the fins to support the pipe.
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Your best bet is probably to deal with a painting contractor to refinish the separable pieces in the shop and do the others in place. Paint remover and rust resisting primer followed by finish should do the job.
  7. pmonger
    pmonger New Member
    Nov 1, 2008
    Baseboard Heater Covers
    You could always try this solution;
    Looks pretty easy to me.
  8. tonytony
    tonytony New Member
    Jan 29, 2009
    Baseboard covers
    I purchased a few baseboard covers They were shipped to my door in a few weeks. I couldn't be happier!
  9. famattjr
    famattjr New Member
    Feb 11, 2009
    New Jersey
    Today I put a new cover assembly in w/out replacing the actual heating element & it was a PITA. I did not want to drain the system & sweat a new element in, complicated by fact it was in a small bathroom (a 30" Slant Fin unit). Due to being in the bathroom, the outside sheet metal parts were beyond saving. Trouble is the clips that hold the front sheet metal to the assembly that goes against the wall has to be inside the elbows that takes the copper down to the basement. There was one on each side. So I had to slightly bend the clips, which caused them to fit into the sheet metal less than perfectly. If this photo comes out, this is the unit:
Similar Threads: Replacing water
HVAC Heating & Cooling Replacing Gas Boiler & Water Heater. WITH WHAT??? Oct 19, 2011
HVAC Heating & Cooling Replacing an Indirect Water Heater Mar 13, 2007
HVAC Heating & Cooling Replacing everything with Navien combi unit May 11, 2016
HVAC Heating & Cooling Replacing furnace - wondering about flex duct sizing Jun 14, 2015
HVAC Heating & Cooling Replacing a Whirlpool Dryer Element Jun 2, 2015
