replacing flapper on TOTO toilet
Discussion in 'Toilet Forum discussions' started by lz, Feb 2, 2010.
  1. lz
    lz New Member
    Feb 1, 2010
    boston
    I have a TOTO Dartmouth CST754SF. The flapper eyelet that connects to the chain broke. I have two questions: What will be the right flapper replacement? Also, the vertical tube that has the two rods to which the flapper connects sits very close to the back wall of the tank, so that there is no space to remove the old flapper hinge or install the new one. Suggestions?
    thanks for any help you can provide.
  2. Terry
    Aug 17, 2004
    It's the red g-max flapper.
    Korky makes replacements for Toto,
    Lowes Hardware carries them.
    It the pin is too close, you can pull the tank, loosen the large nut on the bottom, and swivel the flush valve away from the side of the tank.
Similar Threads: replacing flapper
Toilet Forum discussions Toilet running randomly even after replacing flapper Feb 7, 2017
Toilet Forum discussions Replacing flapper on Kohler San Raphael Toilet Jun 9, 2012
Toilet Forum discussions replacing flapper Vortens Vienna II Jul 28, 2008
Toilet Forum discussions Replacing flapper assembly cimmaron Aug 18, 2007
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Feb 15, 2017
