replacing flange on copper pipe
Discussion in 'Toilet Forum discussions' started by Richard S, Jan 30, 2005.
  1. Richard S
    Richard S New Member
    Jan 30, 2005
    Washington State
    I'm in the early stage of a bathroom remodel & need to replace the toilet flange. I'm trying to figure out how the flange is attached (glued, sweated, other) & the best way to remove it. I'll have excellent access from both top & bottom as I'm taking the original floor off right down to the joists & on the bottom I just had to remove the dropped ceiling from the downstairs bathroom. All the piping is copper in excellent shape including the bend. Ideally, I'd rather not cut out the bend as I'd hate to cut out perfectly good copper pipe, but will if I have to. Any advice is greatly appreciated.
  2. Terry
    Aug 17, 2004
    [​IMG]
    If it's copper, you might be able to solder on a new one. ​
    Here is a picture of one I took out of a home. ​
    The homeowners were saving water by not flushing their toilet. ​
    The concentrated urine ate the bottom of the copper pipe through. ​
    You see this a lot in bars where they dump a lot of citric (lemons and limes) down the drain. ​
    Photo labs require at least some plastic piping. ​
  4. Richard S
    Jan 30, 2005
    Washington State
    Terry,
    Thanks for your quick reply. After removing the remaining subfloor & throroughly cleaning the flange, it turns out the flange is in good condition. Also, I'm not sure how common my situation is but the flange is copper also.
  5. hj
    flange
    A lot of heat from a good torch will get it hot enough so it slides off.
  6. Richard S
    Jan 30, 2005
    Washington State
    hj,
    Even though the flange appears to be in good shape. It's still the original one installed 37 years ago. Would you recommend removing it anyway. Thanks.
  7. hj
    flange
    Remove it if you have, or want, to change its height. Otherwise use wax rings to adjust for differences unless it will be too high.
Similar Threads: replacing flange
Toilet Forum discussions Problems replacing a rusted out toilet flange... Nov 27, 2015
Toilet Forum discussions replacing ABS toilet flange Sep 1, 2015
Toilet Forum discussions Cast Iron Flange leaded on an ABS Pipe, replacing flange Jan 3, 2015
Toilet Forum discussions Replacing Closet Flange Jun 24, 2014
Toilet Forum discussions Replacing Cast Iron Flange, Not enough concrete to anchor. Jan 11, 2014
