Replacing faucets on 1940's sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by so-sa, Feb 22, 2012.
  1. hj
    we would need a picture of the sink, because your difficulty is NOT normal for any sink of this type.
  2. californialife
    californialife New Member
    Mar 15, 2013
    Los Angeles
    Thank you for responding. Here are some photos:
    As you can see, the faucet hole is set fairly far back and behind the valves.
  3. hj
    That particular faucet is a PricePfister wide spread, but you said it had "clear crystal handles". If this is the faucet you were referring to in the original posting, the valves a NOT 'shot' and are easy to repair to"like new" condition.
    The faucet "hole" should be the same distance as the other two, because that is the way they made sinks back then. At that time the faucets did NOT have "hoses" so all three openings HAD to be exactly in a line. But even if it is offset because of the drain overflow, your "problem" is that the spout has "overhang" at the rear. Not many new faucets use that design so you have the choice of many new ones, including all current Pfister faucets.
Similar Threads: Replacing faucets
Plumbing Forum, Professional & DIY Advice replacing all faucets on a budget Sep 21, 2015
Plumbing Forum, Professional & DIY Advice Question on Replacing Faucets Nov 25, 2008
Plumbing Forum, Professional & DIY Advice Help with replacing shut-off valve Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper DWV with PVC Jan 23, 2017
