Replacing Dishwasher: Can't turn off supply valve!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thegoldenhand, May 29, 2006.
  1. thegoldenhand
    thegoldenhand New Member
    May 23, 2005
    I need help again guys. I am trying to replace a dishwasher. At the same time I am also installing a supply line for my ice maker/water dispenser. I will be using an adaptor for the ice maker/water dispenser line. At the very first step, I am already stuck. I dunno whats going on but I can't turn off my supply valve. It is so hard and won't turn even for a bit. I don't want to force it and make matters worse. What can I do to fix this without having to replace the supply valve itself? Can I spray some WD40 into it? TIA
  2. Terry
    Aug 17, 2004
    You can try something like oil, but if it's old, it may be time to change it.
    In some codes, if there is a check valve or PRV in the system, you will need a hammer arrestor at the dishwasher and the icemaker.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I would trash that adapter and install a real valve and reducer adapters to the ice maker. Those adapter things seem simple enough, but they tend to go bonkers after awhile. As far as the other problem, replace the valve.
  5. thegoldenhand
    May 23, 2005
    I currently have 3 supply valves under my kitchen sink. First 2 is for the hot and cold of the kitchen faucet. The other 1 is used exclusively for the dishwasher. Is this a hot water or cold water line? What does dishwashers normally use?
    Coz if it's hot, then it's not where I will have to connect the adapter for my fridge ice maker/water dispenser line. I will have to connect it to the cold water supply valve that is currently being used by the faucet.
    Anybody know? Hot or cold? Thanks!
  6. Lancaster
    Lancaster New Member
    Nov 7, 2005
    The dishwasher is to be supplied with hot water.
  7. jadnashua
    I've got 4 shutoffs under my sink, H+C for the faucet, a cold for a filter, and a hot for the dishwasher. A bunch of t's...
    What might be simpler, if it is acceptable to you, is to replace the single outlet valves there now with double valves (these have two outlets rather than the more normal one). Hassle is, you lose the supply to the sink when you need to turn the thing off. Benefit is, you don't need a new T and pipe.
    I actually built my cabinets up on a 3" pedestal to make the counter higher...I ran the tubing for the DW and fridge under it, but behind the cabinet, below the floor of the cabinet against the wall should work fine.
Similar Threads: Replacing Dishwasher
Plumbing Forum, Professional & DIY Advice Noisy sink drain after replacing dishwasher Mar 18, 2016
Plumbing Forum, Professional & DIY Advice Need advice on replacing toilet flange Saturday at 4:57 PM
Plumbing Forum, Professional & DIY Advice Replacing sanitary tee Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Help with replacing shut-off valve Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
