Replacing Closet Flange
coalpiper
Alberta
Still ruminating over my closet flange challenges.
So, it looks like one ABS closet flange can possibly be replaced, although access is tight. It would involve putting a 3" coupling on the horizontal line, a short length of 3" pipe, then a 3" elbow, and short 3" vertical pipe. Then up through the floor and put on the new closet flange.
Quite a few glued joints. As this is on original construction, I worry a bit about the risk of cracking glued joints elsewhere in the piping system.
Any experience out there with this sort of thing ? Or am I over thinking this.
coalpiper
Alberta
I guess the other thing is … what is the best way to check for leaks in the piping after the closet flange replacement ? In a new home build don't you do a hydrostatic test ?
In the case of replacement after a new build, you don't really have that option (the hydrotest).
So do you just run a bunch of water through the new fittings setup and check for leakage ?
They call that a running test.
In the crawl? Or higher than that? It's a rare day that I would have a leak on 3"
Very rare.
coalpiper
Alberta
The flange is on the top floor of a 4-level split. There is some access underneath, from the garage.
