Replacing closet flange, twist and set or glue on
Titan7
2nd story bath, old flange cut off already. Should I use another glue on and replace the elbow or just use one of the twist-n-fit flanges that goes inside the 4" drain? I have used the ABS twist and set on another bathroom 4 yrs ago but my plumber is saying glue on is better?? I am tiling the floor so it seemed better to me to have the twist set on the inside of the drain so I can adjust it to the top of the tile floor. It's a non-pressure system so I can't see the advantage of the glue on?
Any suggestions?
You do want the flange attached firmly to the floor, especially so with a clamp on drain. To make things easier on yourself, notch the tile so you don't have to drill through them when getting ready to install the thing. Don't skimp on the screws.
TedL
NY Capital District
Just to build on this....
Put the flange in place temporarily (perhaps upside down) and mark the screw locations so you can cut the tile around them. Use #14 stainless or brass screws.
Titan7
Thanks, that's what I will do. I did one like this 4 years ago with no issues. I did not drill into the tile. Since I did not know how high the finished floor would be I left the drain alone and had it tiled around it. I then made a spacer 1/2" plywood that fit around the drain and then I could insert the oatly twist set into the drain and it was about 1/8" above the level the tile. I used #12 stainless screws to secure the flange to the new floor. That's what I was planning to do this time.
The only reason I was thinking of a glue on is I need to replace a large section of subfloor in the other bathroom so I will have total access to the flange and elbow.
If you have total access, glue a new one one, but still screw it to the floor. Put the tile under it so it is firm.
