replacing baseboard
Discussion in 'HVAC Heating & Cooling' started by richb2, Jul 19, 2008.
  1. richb2
    richb2 New Member
    Feb 12, 2006
    New York
    We recently had our bathroom redone and the plumber put in a new baseboard which looks great. I now want to replace the two baseboards in my kitchen. What is the process? Do I need to "drain" the system and then refill it? How do I do this? How will I remove the old ones? Do I cut the copper tubing with a tubing cutter and then solder the new ones in place? Any links would be appreciated.
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    Yes, you need to first drain the system, at least to a point lower than the baseboard units you will be replacing. You would probably be better to unsolder the existing baseboards because if you cut the piping then it may be too short to solder the new ones in place. After replacing the units you would then refill the system and bleed the air.
    Why do you want to replace your baseboard convectors? If it is purely for aesthetic reasons you might prefer to just replace the housings. It is a bit of work depending on how the originals are fastened in place (nails instead of screws) but it is probably cheaper and easier than replacing the plumbing parts also. You can buy just the housings.
  4. richb2
    richb2 New Member
    Feb 12, 2006
    New York
    Well these baseboards are on the first floor while the oil burner is in the basement. I need some written instructions on how to bleed the air.
    I am not sure which part is the convector.
    x
    x zz y
    x zz y
    x zz y
    x zz y
    This is a side cut through view. The x part is attached to the wall (with nails). The zz part is the fins. The y part is a cover. The roof of the x and the y parts are painted with old paint. I am not sure you can get the x part out without removing the fins (zz).
Similar Threads: replacing baseboard
HVAC Heating & Cooling (Simple - I think) question on replacing thermostat for baseboard electric heat Dec 8, 2010
HVAC Heating & Cooling Replacing hydronic baseboard radiators Feb 25, 2008
HVAC Heating & Cooling Replacing hot water baseboard heating Feb 16, 2007
HVAC Heating & Cooling Replacing Chimney Mar 23, 2017
HVAC Heating & Cooling Replacing everything with Navien combi unit May 11, 2016
