Replacing an American Standard Lexington toilet.
Discussion in 'Toilet Forum discussions' started by noeffort, Feb 9, 2008.
  1. noeffort
    noeffort New Member
    Feb 9, 2008
    70.134.226.124
    Terry,
    Came across your site while doing a search for toilet reviews.
    Excellent information.
    I have a 76 Ameircan Standard mode Lexington one piece that has caused nothing but aggravation over the years.
    Between leaking and getting plugged up I'm ready to take a sledge hammer to it.
    I would like to go with a toto drake cst744sg (i'm in CT).
    Question is I hope it will fit. Without removing the toilet where is the center of the drain? Is it where the bolts are?
    The tank looks like it is angled back in the pictures at your site, is this true?
    And what is sanigloss? Found answer: Super smooth, ion barrier glazing cleans your toilet bowl with everyflush.
    Is is necessary to get an insulated tank?
    Thank you
    [​IMG]
    Toto Drake
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The rough in is measured from the center of the drain to the finished wall. So, how do you tell where the center of the drain is without pulling the toilet up? Measure from the flange bolts. They are centered on the drain.:)
  4. noeffort
    noeffort New Member
    Feb 9, 2008
    70.134.226.124
    thanks gary
  5. Terry
    Aug 17, 2004
    I've only sold a few insulated tanks.
    Unless you have very cold water and high humidity, it's not needed.
    Since not all the water leaves the bowl, the water doesn't get that cold in the tank.
    If someone in Seattle wants insulated, I do have one.
    The tanks don't lean. Maybe it's just the camera lens, or the angle I took it from.
Similar Threads: Replacing American
Toilet Forum discussions Identifying and replacing broken cylindrical American Standard Champion flush valve,. Apr 21, 2016
Toilet Forum discussions Replacing an American Standard 30yr old toilet Apr 29, 2015
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Wednesday at 8:51 AM
Toilet Forum discussions Toilet running randomly even after replacing flapper Feb 7, 2017
Toilet Forum discussions Replacing Toto Ultimate round bowl, 14" rough in - no knee room Jan 21, 2017
