Replacing a tub drain assembly
Discussion in 'Shower & Bathtub Forum & Blog' started by annewb, Jun 18, 2007.
  1. annewb
    annewb New Member
    Jun 18, 2007
    Hi. I am attempting to replace a lift and turn tub drain replacement assembly. When I screw it it goes in crooked and does not screw far enough in to be flush with the tub...perhaps i need a little more strength! ha! :) I have the old one out and tried to simply screw the new one back it. It looks like plumbers putty (?) was used to install the previous one. Do I need to use it for this new one? Do I need to remove old putty? HELP!! Thanks for any advice.
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Remove the old plumber's putty and use fresh plumber's putty under the new drain flange. Use this tool ("smart dumbell") along with a large crescent wrench to tighten it up, and don't cross-thread it.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    If the new one is plastic be carefull not to X thread it while attempting to install it.
    You also don't need 400#s of putty, just enough to seal between tub and part being installed. If you use to much you may end up with a leak down the road.
  5. mdhills
    mdhills New Member
    Aug 20, 2007
    When doing this replacement, do you also need to replace the washer between the drain pipe and the tub? (if so, can this typically be done from the top side, by pressing the drain down a bit and wedging the washer in?)
  6. jadnashua
    YOu can do it from the top, but be careful, if you drop it or it slides where you can't access it, then you'll need another one, or tear things out. Maybe slide something in the pipe to keep it from straying? I've only done a few, and they went okay.
Similar Threads: Replacing drain
Shower & Bathtub Forum & Blog Leaking shower drain: help replacing from top Jul 1, 2016
Shower & Bathtub Forum & Blog Ran into a small problem replacing drain. Mar 5, 2016
Shower & Bathtub Forum & Blog Replacing bad shower drain fittings with new. Sep 22, 2014
Shower & Bathtub Forum & Blog Replacing Cast Iron Shower Drain With PVC Apr 4, 2014
Shower & Bathtub Forum & Blog Replacing Cast Iron Shower Drain / P-Trap & Replacing with ABS Aug 29, 2011
