Replacing a Porcelain Sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jerome8283, May 30, 2009.
  1. jerome8283
    jerome8283 New Member
    Oct 4, 2006
    New York
    Hey Guys,
    I need to replace my bath porcelain sink. The sink is oval and under-mounted to granite. It has clamps, what appears to be silicone as well as wood supports that came with the cabinet. Would simply removing the clamps with a little shimming get the old sink out? Can someone offer some pointers on this as well as installing the new sink? I've read that some use epoxy? I'm not sure if this sink was installed using epoxy but if so how do I remove it?
  2. jimbo
    jimbo Plumber
    Given the mechanical supports you describe, there should be no epoxy. But it will be caulked.
    Figure out how to remove the clamps and the wood blocks. Then use a stiff putty knife in the joint to break the caulk joint. Do all this with your two hands, while holding up the sink with the other two.
    Plan on putting the new sink in the same way.
    I have seen some "experiments" with installing undermount sinks with epoxy only, and I consider it not reliable.
  4. jerome8283
    Oct 4, 2006
    New York
    Looks like a two person job. Thanks ;)
  5. jerome8283
    Oct 4, 2006
    New York
    I got it off. It was silicone. thx
Similar Threads: Replacing Porcelain
Plumbing Forum, Professional & DIY Advice Help with replacing shut-off valve Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper DWV with PVC Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Replacing a backup Zoeller 507 with something higher in capacity? Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Replacing a Hydromatic DA-1 10 with a Zoeller M98 or Liberty 287 Jan 3, 2017
