Replacing a lead soil tube
Discussion in 'Toilet Forum discussions' started by ChrisTyrrell, Sep 20, 2004.
  1. ChrisTyrrell
    ChrisTyrrell New Member
    Sep 20, 2004
    While remodeling a bathroom (built in '52), I had to destroy the existing brass flange and soil tube in order to remove the flooring (Ok, I didn't HAVE to, but I did it anyway because I don't know what the heck I'm doing). The soil tube was lead, attached to a slightly larger pipe (not lead, not cast iron, galvinized I s'pose) which is then seated (and apparently soldered) in the cast iron closet bend.
    If I can remove everything down to the closet bend, how shall I connect my new 3" PVC to the closet bend? :confused: If I can't do this, then I'll call the plumber, but I really don't want to call the plumber. $$$
    I have access from above and below, and I'm picking up a Bernz0Matic this evening to begin removing the remants of the old soil tube.
    Sincerely,
    Chris
    Des Moines
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Replacing a closet bend
    [​IMG]
    It probably needed to be replaced anyway so don't sweat it, 50+ years old!
    Melt the lead off of the ferrule, (the wipe joint near the cast iron hub) and install a transition coupling. Fernco Pro-Flex is a good quality coupling for this purpose. Make sure you wipe all the lead from the brass ferrule. Make the transition to PVC with the appropriate size coupling. Don't forget to anchor the new closet flange to the floor.
  4. Jotus
    Jotus New Member
    Sep 19, 2004
    Related question to replacing soil tube
    How do you connect PVC to a 4" cast iron pipe with a hub?
  5. e-plumber
    Sep 1, 2004
    New York
    Lead Bend Replacement
  6. ChrisTyrrell
    Sep 20, 2004
    Thanks for the help - it worked
    Your help regarding my lead soil tube was right on. I was originally planning on beginning with removing the solder around the ferrule, but I'm so glad I didn't after reading your advice. The ferrule turned out to be 3", just like my PVC and the Fernco coupler I had already bought. It all fits together like a champ.
    Tomorrow, I'll be installing DurRock, then tile, then I'll fasten the flange and be all set to go.
    Thanks again for your help.
    Chris
Similar Threads: Replacing lead
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
Toilet Forum discussions Cast Iron Flange leaded on an ABS Pipe, replacing flange Jan 3, 2015
Toilet Forum discussions Replacing lead bend clarification Jan 29, 2009
Toilet Forum discussions HELP-Replacing Closet Flange/Lead Soil Pipe - suggestions Aug 10, 2005
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Wednesday at 8:51 AM
