Replacing a Delta Shower faucet w/diverter
Discussion in 'Shower & Bathtub Forum & Blog' started by av8tor50, Feb 13, 2007.
  1. av8tor50
    av8tor50 New Member
    Feb 13, 2007
    Middle of Somewhere
    I am replacing a Delta shower faucet and have unscrewed the faucet, but there is a threaded sleeve on the pipe coming out of the wall that I cannot see how it is attached...maybe sweated to the 1/2" pipe?
    The other problem I fear, is that I have twisted the stub pipe that I'm pretty sure is sweated in place behind the tub/wall. Won't know if it leaks till I try it I guess. :(
    Any help is welcomed!
    Mike
  2. Cass
    Cass Plumber
    Nov 12, 2005
    It is sweated on.
  4. hj
    spout
    If you did the right thing, you would have bought another Delta spout, it is not the faucet, and screwed it onto that adapter.
  5. av8tor50
    av8tor50 New Member
    Feb 13, 2007
    Middle of Somewhere
    Thank you.
  6. av8tor50
    av8tor50 New Member
    Feb 13, 2007
    Middle of Somewhere
    Yea, hj, I knew that. Thinking spout, wrote faucet. :rolleyes: HD 'nor Lowe's carries that spout and couldn't find it on Delta's site, any suggestions on where to buy that spout?
  7. hj
    diverter
    It is called a "pull down diverter" and is used on almost all of their tub/shower units. If you call Delta, they would probably send you one.
  8. Dan Pick
    Dan Pick New Member
    Feb 11, 2007
    Plumbing Sales
    Speedway, IN
    Pull down diverter tub spout
    You need to order a Delta RP5836. The LIST price is $23.71. Be sure to lubricate the o-ring prior to installation.
Similar Threads: Replacing Delta
Shower & Bathtub Forum & Blog Replacing a Delta 1300 series with a 1700 series Dec 28, 2011
Shower & Bathtub Forum & Blog replacing delta single level shower lever Oct 17, 2005
Shower & Bathtub Forum & Blog Replacing Bathtub Jan 6, 2017
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
Shower & Bathtub Forum & Blog Replacing tub valve set: which side of the wall to work from? Nov 10, 2016
