Replacemnt of original 1940's Standard Modernus Toilet
Discussion in 'Toilet Forum discussions' started by CHRISB, Jan 21, 2007.
    CHRISB New Member
    Jan 21, 2007
    I am trying to ascertain the best way to replace an existing toilet in my house built in the mid forties. I have an original (it appears) Standard Modernus toilet that is a two piece that is presently in place. I just want to update toilet to a modern one and I am afaid if I start the project it may end up bigger than I anticipate. I am handy and have installed new toilets but never when the original was this old. My secondary problem is I will have limited access below the bathroom to access if needed. Any advice I what I should attack first? I am not even sure if old toilets are compatible with the new ones.
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    The most important queston: Is it your only toilet?
    Secondly, are there any problems with the curent toilet's mounting (rocking, moving,etc.) What's the sub floor material? Finish floor? Does it sit directly on the finished floor? Are you changing the floor?
    If not, covering the footprint of th old toilet could be a major issue, especially if your current floor was installed around it. If it's tile that runs underneath, that probably would clean up OK if the new foorprint doesn't cover the old.
    The input and output connections are pretty much the same, though made with different materials today.
Similar Threads: Replacemnt original
Toilet Forum discussions Toto Drake - original flapper replace or fix - part # confusion Jan 27, 2016
Toilet Forum discussions Can't locate TOTO Original Flappers or at least the rubber seal gasket. Feb 10, 2015
Toilet Forum discussions Map score of the original Toto Carolina? Oct 28, 2014
Toilet Forum discussions Cadet 3 original flapper fix. Oct 3, 2010
Toilet Forum discussions Replace Briggs, originally Case, 3000 low profile wall mount or just flush valve? Nov 11, 2008
