Replacement of Hold Down Ring
Discussion in 'Toilet Forum discussions' started by dw85745, Oct 14, 2004.
  1. dw85745
    dw85745 Member
    Oct 14, 2004
    Tucson, Arizona
    The metal ring which is surrounds the ABS pipe and to which the toilet is attached is rusted out and the left side toilet bolt cannot be tightened.
    Any way to fix without ripping out the ABS?
  2. hj
    flange
    I have replaced many of them without "ripping out the ABS", but you can remove that ring and then install a two piece replacement that "bolts" in its place around the existing ABS pipe.
  4. dw85745
    dw85745 Member
    Oct 14, 2004
    Tucson, Arizona
    Thanks for response hcj. Will see if I can find a split ring.
    Any suggestion about getting the old ring out and off the ABS.
    One thought was a dremel tool with ginding wheel and grind through the ring on both sides to split it.
  5. hj
    ring
    One side and twist it off.
  6. Terry
    Aug 17, 2004
    [​IMG]
    You could also use a repair flange over the existing one. ​
Similar Threads: Replacement Hold
Toilet Forum discussions What is the correct (or best) replacement flapper for a Toto Drake II? Tuesday at 3:44 PM
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions Norris toilet replacement with a Toto? Jan 31, 2017
Toilet Forum discussions Intermittent hissing noise from Toto fill valve even after replacements Jan 11, 2017
Toilet Forum discussions Toilet still runs after flapper and valve replacement... Jul 30, 2016
