Helpful Mom
I just replaced the gasket and bolts connecting the tank to the toilet, toilet fill valve and bought a new toilet water line. Everything is hooked up and the tank is solidly bolted to the stool now with no leaks. I have two issues with the fill valve though. First, water is overflowing into the overflow pipe. Do I have to remove the whole fill valve in order to change the height? Secondly, I now have a new leak where the supply line is attached to the fill valve. It looks like it's coming from inside the tank. I hand tightened the nut per the instructions. What did I do wrong? Also, I notice the water shut off valve had a tiny little leak when the water was turned off. Could this be the problem? Thanks!
