Yar02169
23' deep, water 7' below ground. Goulds GT15 pump.
Replaced box store bronze check valve (1 1/2") with an Apolo SS ball check valve of the same size. Used goopy thread sealer instead of Teflon tape, hoping to eliminate any leaks.
Assembled, primed and hit go. After a bit, some flow comes out the outside hose bib, but pressure remains zero and no flow increases.
The CV is cold, the PVC from the well is more half-cold; the bottom half.
I used a better sealing technique, so I would like to eliminate an intake leak. Is it possible that the new check-valve closing spring is to strong? I did activate both with my finger, and the new did feel a touch stronger, but I'm rethinking it's strength.
Should I let the pump run for a while so it can pull the air slowly out of the supply side? Once full of water, the pump would pull what's needed, correct?
